Recording unit diagram
Indicator of Switch positions
Indicator of Function Keys
Indicator of LED colors
Technical Specification
Video File Name and Protection
User Manual for INNOVV C3
Please review and download it from the below downloadable resource.
INNOVV C3 Firmware Update Procedure
Downloade the last version from the below downloadable resource.
Update Procedure- you also can refer the FW upgrading instruction video from Bobflyman
Download latest FW from below downloable resource and Unzip file.
Insert SD card to your camera, it should be class 10 or above.
Plug in camera to PC. Turn the camera on, PC should see the camera as a drive and give it a drive letter.
Open the drive and delete any files you see (after saving videos you may have taken of course!) Then delete DCIM folder.
Copy bin file to now empty card (shown as drive)
Leave camera plugged in. Turn off camera. Wait a second or two. Turn on camera. LED should flash slowly, then after a few seconds quickly this shows FW is being updated.
DO not switch on or off, or unplug while LED is flashing or you may destroy camera.
Then a few more seconds later LED will stop flashing.
Unplug camera. File is automatically deleted and FW is now updated. Your previous setting will have been saved such as no date stamp, auto power off, etc.
INNOVV C3 GUI Update Procedure
Download the last version GUI from the file name-C3 FW &GUI _20150303 from the below downloadable resource.
Update Procedure
Download the GUI programme from the below downloadable resource.
Execute the GUI programme on your computer.
Set the camera settings as you require then click 'Save Configuration file'Plug in your camera with the usb cable provided
Turn on the camera and your pc will see the camera as an external drive.(You may need to open Windows Explorer or click My computer to see drives.)
Click on 'Save to camera' and select the camera shown as a drive.
Leave the camera plugged in and turn off.
Then turn on again.LED will flash for a few seconds and the stop flashing.
Turn off the camera and unplug the cable.
The new settings have been saved.
The GUI file is deleted automatically.
INNOVV C3 GUI from www.2kool4u.com
Thanks for Bob, he designed the friendly using GUI, click the above website name to download the GUI and install it to your computer for setting.
The GUI has the ability to read last saved config file using the "Configuration File Tab", you can see your last saved settings there...then modify settings and re-save...each time the "save to camera" button is pressed it updates and saves the new settings in this window...
INNOVV C3 GUI manually setting for Mac and Android
Download The C3 The C3 Mac and Android setting.rar from the below downloadable resource.
Manual Settngs:
Open the enclosed c3config.bin file with notepad or text editor.
Using the reference list above manually change the parameters of c3config.bin.
When finished save the file as c3config.bin directly to sd card or to folder on your pc.
With the new c3config.bin file on sd card restart camera to update settings.
How to connect INNOVV C3 to your PC
The lens cable must plug in the recording unit before connection.
How to connect INNOVV C3 to Smart Phone or Tablet
Plug the below male micro USB plug of the OTG cable into either smartphone or tablet.
The USB data cable connects the female USB plug of the OTG cable, and the port of C3.
The Smart phone or Tablet recognises the INNOVV as removable storage (like a USB stick).
Download ES File Explorer app and install it to your smart phone or Tablet to review recordings or copy recordings to your devices.
The Instruction for the basic operation
To avoid damaging the camera and the best understand the buttoms and functions,
Please watch the video from Bobflyman before start it up.
The FW and GUI upgrading log
Click blow to download Firmware, User Manual, Video clips
