INNOVV C5 Motorcycle Camera Installed on Suzuki hayabusa
Attached is some photos of the current INNOVV C5 motorcycle camera install and the rubber grommet I used.
I’ve also attached two photos from the old install on my Hayabusa.
On the new install, I cut one of your washers at an angle so the camera could be level although the fairing is at a slight angle and located this between the camera bracket and my softer washer/grommet. Whilst this got rid of most the vibration caused by engine resonance, I now get camera shake caused by wind pressure at motorway speeds. We definitely need a new solution as neither work. If the lens is secured very tightly the original bracket works at speed provided engine revs are above or below the resonance level (<4500 or >5500 rpm). My softer washers, nearly cure the engine resonance when stationary or at low speed, but allow the camera to move at speed (60+mph).
#motorcycles #INNOVVC5 #motorcyclecameravideoclips #Motorcyclecamera #Motorcycledashcam #Innovvmotocam #motorcyclecamera
Featured Posts
Category
Archive
Tags
Follow Us
  • Facebook Basic Square
  • Twitter Basic Square
  • Google+ Basic Square
Rss Button
RSS Feed
