INNOVV Power Hub1 Install on BMW R1200 GS
I got INNOVV Power Hub 1 to power extra accessories like phones and my two GoPros. It gives you 5 circuits switched 12 volts with a 5 amps fuse per circuit. The fuse can be replaced per your need, Max 15A is for a single circuit, Max 40A is for total 5 circuits.
I liked this because it's water and dust proof plus it's very cheap. The full details can be found here http://www.innovv.com/innovv-power-hub1-cjxt
The Power Hub 1
The size
The Leads,
The lead to the battery were far too short so I needed to buy extra wire to lengthen the cables.
I also added superseal connectors on the four of the leads and a SAE connector on the last one.
You get a single ground lead and I tied all 5 grounds to this single lead.
I used the rear tail light feed for the trigger wire.
The install,
The unit fits absolutely perfectly under the tail section on my 2016 BMW R1200GS.
#INNOVVPowerHub #Motorcyclepowerdistribution #motorcyclepowermanagement
Featured Posts
Category
Archive
Tags
Follow Us
  • Facebook Basic Square
  • Twitter Basic Square
  • Google+ Basic Square
Rss Button
RSS Feed
