INNOVV K1 Motorcycle camera extension cable
This is what I need to do on my install! I need to be able to put it in my tour pack. This is why a 3' longer cable is needed. Please let me know what to do. - Toby. (INNOVV Motorcycle camera K1 install on 2016 Harley Road Glide CVO Ultra)
I had ordered a 64gb class 10 micro sd card as well as several 5 wire micro USB extenders in
case the camera cables we not long enough. I bought mine on Amazon and you have to specify "5 wire" not the standard 4 wire ones. I could only find 1 foot length so I ordered 3 of them.-by Tom King. (INNOVV K1 Motorcycle dashcam install on 2015 Goldwing GL1800)
Hi Rock - Per our chat, here's the link of the micro-USB extension cable I employed to help move the DVR under the pillion seat and further away from the engine heat. (The extension cable for front camera)
YCS Basics One Foot USB Micro Male to Micro Female 5 Pin / 5 Wire Extension Cable
https://www.amazon.com/dp/B0134XUJN2/ref=cm_sw_r_cp_api_Z3FyxbWH30ZZZ
Update,
Thank William Fussell, He found and tested below cables and it works well.
http://www.usbfirewire.com/parts/rr-mcb-ext-xxg.html​
"Work perfectly. They have many different lengths to pick from for Micro-B to Micro-B 5-wire extension cables. "
Available Part Numbers
  • PART# RR-MCB-EXT-05G5, SIZE: 5in (127mm)
  • PART# RR-MCB-EXT-12G5, SIZE: 12in (305mm)
  • PART# RR-MCB-EXT-24G5, SIZE: 24in (610mm)
  • PART# RR-MCB-EXT-72G5, SIZE: 6ft (1829mm)
  • PART# RR-MCB-EXT-180G5, SIZE: 15ft (4572mm)
#Extensioncable #Innovvmotocam #Motorcycle2Channelrecordingsystem #MotorcycleGPS #Motorcycledashcam #Motorcycletracking #ridingcamera #MotorcycleDVR #motorcycleblackbox #motorcycleridingcamera #Motorcyclerecordingsystem #Innovvmotorcyclecameraaccessories #motorcyclecamera #Motorcyclecamera #motorcyclecameravideoclips
Featured Posts
Category
Archive
Tags
Follow Us
  • Facebook Basic Square
  • Twitter Basic Square
  • Google+ Basic Square
Rss Button
RSS Feed
