INNOVV C3 camera rear mount for Kawasaki Ninja 250r
This is a simple camera mount for the Innovv C3 to fit the 2008-2012 Kawasaki Ninja 250r motorcycle by firacer98, Looks smart and cool!!
Just thought I'd share this mount with you guys. I designed it in Sketchup and printed it on my Da Vinci 3D printer. It uses the existing hole that is present on the fender. The C3 is almost exactly the same size as the hole! The adapter will fit the barrel of the C3 quite snug so it won't turn.
It's designed to fit on the stock rear fender. The stock fender has 3 holes, and the center hole is practically the same size as the diameter of the C3 bullet camera. It seemed like a logical place to put it. I included the original Sketchup file in case you need to modify it.
It was printed on a Davinci 3D printer at 400microns (0.4) layer height with 20% fill. During my test prints, I've done them at 5% fill and it worked too, just not as strong but it'll also work.
It uses two M6, 25mm bolts to fasten. You can probably go with shorter bolts, like maybe 15mm since the thickness of the mount is only 10mm anyways. I only used 25mm cause that's what I had. No nuts need since the bolts are pretty tight in the holes. I would also suggest washers as well to cover up the existing holes better. I painted mine with black vinyl paint since pink doesn't match my bike.
I uploaded the file to Thingiverse if anyone is interested in printing their own.
http://www.thingiverse.com/thing:687322
#innovvc3 #motocam #motorcyclecamera #ridding
Featured Posts
Category
Archive
Tags
Follow Us
  • Facebook Basic Square
  • Twitter Basic Square
  • Google+ Basic Square
Rss Button
RSS Feed
