Introducing The New INNOVV ThirdEYE
After a year, INNOVV is proud to announce a new product called INNOVV ThirdEYE, a unique blind-spot detection and alert system designed for motorcycles.
It is a sensor system that keeps an eye on your blind spot and gives visual warnings when vehicles are detected around you. Designed as an additional safety system for motorcycles, it gives you additional visibility on the road and warns you and other road users when there is danger.
You’re probably aware of the growth of blind-spot detection systems in cars. They are a system that uses sensors that detect other vehicles and give a clear visual warning for areas around the vehicle that you cannot see. ThirdEYE is a retro-fit solution that gives you the same safety system for your motorcycle. The system actively monitors the traffic behind you as you ride and gives you visual indications of movement in your blind-spots. It is designed specifically for motorcycle safety and adds enhanced visibility for the motorcyclist to enhance rider safety – it’s like having eyes in the back of your head.
ThirdEYE features a unique sensor system designed specifically for motorcycles. This provides the rider with enhanced all-round awareness to increase safety.
Lane change warning system
When switching lanes, ThirdEYE is there to offer enhanced warnings. For example, when passing on the right lane, the triangle symbol on the left mirror and square symbol on both mirrors will flash in sequence. This is to increase safety during lane changes.
Alerts the motorcyclist about the presence of relevant objects.
Eliminates momentary head turn distractions to see vehicles in the blind spot
Advanced Sensor
The sensor uses the latest Frequency Modulated Continuous Wave (FMCW) technology.
Here the carrier frequency is constantly modulated within a small range (the bandwidth).
As soon as the signal is reflected back from an object, it measures the distance and the speed of the object through frequency comparison.
Brake light warning system
Your personal space is sacred to you and your safety. ThirdEYE uses your motorcycle brake light to warn vehicles around you that they are invading that space and putting you at risk. The brake light will flash slowly if the system detects vehicles behind you within 5-10 meters and will quick-flash if a vehicle encroaches within 5 meters – it’s a clear and visible warning that categorically says “You are TOO CLOSE to my motorcycle – BACK OFF!”
Ready to fit to any motorcycle
ThirdEYE comes with everything you need to retro-fit the system to your motorcycle. Just like our cameras, the system is a permanently fitted solution for your bike.
Mirror Version
Watch Version
The old adage “See, and be Seen” Runs Both Ways!
Be safer, be seen with INNOVV ThirdEYE.
