Introducing INNOVV K5 Dash Cam: Like an Action Cam, More Than an Action Cam
What would you use to protect yourself with the full coverage and record the wonderful moments during your road trip? Generally, an action cam will be chosen to record the wonderful moments with its 4K video quality and a dash cam will be chosen to protect yourself with its versatile features like loop recording, G-Sensor, and others.
But now the INNOVV K5 dash cam enters the game and packs all these features into it. There is no doubt that the INNOVV K5 dash cam is one of the most advanced dash cams for powersports (motorcycles, ATVs, UTVs & more) and it is more powerful than a simple action cam. Why it stands out in the market? Keep reading to find the answer!
Innovates with 4K Video and Other Features Like an Action Cam
The INNOVV K5 innovates with the Sony’s 8-megapixel sensor on its front camera, producing strikingly clear 4K Ultra HD footage at 30 FPS, with 4 times as many pixels as in Full HD. Its rear camera provides crisp 1080P HD video quality. Both cameras adopt with an expanded 120° field of view to provide complete coverage around.
Several types of video resolutions are available for both front and rear camera, and you could easily choose the most appropriate one to record your wonderful road trip via INNOVV App on your smartphone.
The INNOVV K5 dash cam is the first one to be compatible with dual-band Wi-Fi among INNOVV family. It allows you to connect your smartphone or tablet directly to the INNOVV K5 dash cam via a Wi-Fi connection and toggle device settings without extracting the Micro SD card. The dual band Wi-Fi (2.4 Ghz/5.0 Ghz) is noteworthy for its fast transmission and more stability, giving you the ability to effortlessly view, download, and share your adventure with your friends via INNOVV App.
*INNOVV App is available on both App Store and Google Play Store.
Speaking of the design, INNOVV dash cams are always praised for their simple and rugged yet stylish design, and INNOVV K5 continues this tradition. The whole device is constructed of durable and lightweight aerospace aluminum alloys, featuring a stylish appearance and enabling a better anti-electromagnetic interference capability at the same time. It is also certified with an IP67 rating, meaning that it could withstand the rain, snow and dust. It is no doubt that the INNOVV K5 dash cam could perform well even in harsh weather conditions with its high-end design.
INNOVV K5 dash cam is a large step forward when compared to its predecessor in terms of the Microphone. Its external Mic upgrades the audio quality from a tinny sound to a resonating voice. It could clearly record your voices during road trip by attaching it to the helmet, making it a helpful gear for the motovlogging. What is more, it could record awesome engine or exhaust sounds by placing it on the right place.
Packed with Features a Dash Cam Must Have, Making It More Than an Action Cam
The INNOVV K5 dash cam is more capable than an action camera in terms of it includes features a dash cam must have, which are not supported by a simple action camera.
Among all dash cams, the INNOVV K5 dash cam gets its place because of its smart Remote Control. You could conveniently check the Wi-Fi, DVR and GPS working status with the LED indicators on the Remote Control during your road trip. Never miss a moment with the Function Button on the Remote Control, capturing scenes with photo taking or video saving by simply pressing the function button for a specific times, without taking hands off the handlebar and eyes off the road.
All INNOVV dash cams are well received for its auto On/Off recording technology, which are designed to operate in a ‘install & forget’ manner. As soon as the ignition is turned on, the INNOVV dash cam will start to record automatically. When the ignition is turned off, the INNOVV dash cam will perform an automatic shutdown process. You will not bother with booting, setting up modes or checking battery status when you use an action cam. Therefore, an action cam will not be as convenient as INNOVV K5 dash cam with its manual start/stop every time and its limited battery life.
In addition, it includes other must-have features as a dash cam.
GPS module: It comes standard in all dash cams since it is highly useful in daily use. The INNOVV K5’s GPS module innovates with a fix update rate of 5 Hz instead of 1 Hz, creating more detailed and higher resolution tracking capabilities. With a fix update rate of 5, new location updates every second (5 Hz) and a baud rate of 38,400 bits per second, the data uses 38,400 bits every second. For faster update rates, bits will be more and will be pushed to processor faster. It helps to decrease display lag time and improves distance measurements and tracking especially when moving on a curvy route at high speed.
H.265: The INNOVV K5 integrates the latest video compression technology, H.265, which is the standard in 4K video broadcasting and streaming. With this, you could enjoy the high-level video quality and save storage space at the same time.
Support Up To 512GB: The INNOVV K5 is packed with a large 512GB microSD memory card capacity to enable longer recording times, which is 3 times more storage capabilities of most 128GB capacity dash cams on the market.
Loop Recording: It allows for continuous recording, even if the SD memory card reaches full capacity.
Parking Mode: The K5’s smart power supply module triggers parking mode automatically to provide around-the-clock protection when you are away.
All in all, the brand new INNOVV K5 dash cam is designed and built for those who demand more for powersports.
If you would like a dash cam with versatile features to protect yourself and record the fun during the road trip, the INNOVV K5 dash cam suits your needs better than other action cameras or dash cams.
About INNOVV:
INNOVV TECH was created by Rock Liu after he left the German luxury packaging company which has more than 150 years history for the high-quality design. He knew that stylishness, elegance, innovation are rare and invaluable, and can bring pleasure to people for another 150 years or forever. So did he in powersports industry and established the INNOVV TECH.
Powersports are the activities for fun and joy which is from the bottom of heart, and INNOVV Tech always follows that. The fans said, it is the pleasure to own the products and share the wonderful moments on the roads with others.
If you’re new to INNOVV products, you’re warmly welcome to join our INNOVV Forum to learn what other users love about INNOVV.
