.jpg)
Solid Build, Simple Design, Easy to Use!
_JPG.jpg)
Extreme Energy Saving Technology
The new and improved INNOVV Power Hub 3 adapts unique energy saving technology resulting in a Standby Current less than 10uA and a no load power consumption less than 0.2W!
_JPG.jpg)
Supports Up to 5 Devices
The INNOVV Power Hub 3 is designed to connect up to 5 electronic devices at any one time.
_JPG.jpg)
Multi In-Line Fuse Protection
Each positive wire is augmented with an independent in-line fuse for protection of up to 5 devices.
Max output for each wire is 5A and 15A for all wires occupied. Each wire is included with a 3A fuse which can be swapped out as needed.
_JPG.jpg)
High-End Durability & Waterproof IP67
Like all other INNOVV products, the Power Hub3 is designed for durability in harsh environments. The system can easily be used and maintain functionality in a variety of conditions utilizing its new IP67 waterproof rating.
_JPG.jpg)
Car
Motorcycle
Snowmobile
UTV
ATV
WaterCraft
Multi-Use Application
This third generation Power Hub is not only compatible with motorcycles, but a variety of land and watercraft vehicles too!
_JPG.jpg)
Overview
_JPG.jpg)
