INNOVV Power Hub 2 is developed in response for customers' need as below.
I like INNOVV power hub 1, it's powered with the ignition so it turns on and off with the bike. A shared ground connection keeps everything tidy, and it's simple, easy to use rugged, and it's very inexpensive.
I just have idea, that if possible you can make the size to even smaller?
So here you go...!
INNOVV Power Hub 1 is developed in response for customers' need as below.
Hi INNOVV, Can you guys develop a power management box to get a reliable switched power source for your motorcycle camera and other devices installed on my motorcycle? It should be simple, solid build, and reasonably priced. Most of the similar products that are available are over complicated and over priced.
Thank you, Eric William.
Reduce the clutter of battery wires by using this unique switched power hub to easily connect up to 5 devices.
The "Power Hub1" will manage the power supply to your expensive devices when the vehicle is turned on and off. We designed a voltage stabilizing feature by adding a 10 second power on delay to allow the system to provide the full power needed to your devices. The voltage to your devices is protected by using individual fuse connectors.
Simple Design
Solid Built
Rain Proof
Dust Proof
Easy Using
POWER HUB 2
POWER HUB 1
POWER HUB 2
1 x 20A inline fuse for input
5 x 3A inline fuse for output
Connecting up to 5 devices
POWER HUB 1
1 x 40A inline fuse for input
5 x 5A inline fuse for output
Clear indicator
10 seconds power on and power off delay to avoid low power supply to devices when engine start/stop.
Power Hub 2
Blue LED solid on, power supply.
Power Hub 1
Red LED light up, the device is failed.
Blue LED flash, 10 seconds power supply delay.
POWER HUB 2
POWER HUB 1
Power Hub 1 install on BMW R1200 GS
