Wires & Connection
Ignition trigger- yellow wire - connect to switched power source like head light, trial light, horn.
This wire is sending electrical signal to trigger power supply for 5 red positive (+)  out put leads.
Positive(+) power lead (Input)- Red wire - connect to the positive point on battery from bike.
Ground(-) (Input)- Black wire - connect to ground point on battery or frame of bike.
Positive(+) power lead (output)- Red wire - connect to the positive lead of the device.
Ground(-) (output)- Black wire - connect to the ground lead of all devices.
Power Hub 2
Power Hub 1
LED Indicator & Power on/off Delay
Once ignition on/off, the connected devices/accessories will power up/off after 10 seconds delay that is to avoid power supply to devices drop down when engine start/stop.
Power Hub 2
Blue LED solid on, power supply.
Power Hub 1
Red  LED light up, the device is failed.
Blue LED flash, 10 seconds power supply delay.
Power Hub 2 Input & Output
Input, the max is 20A.
Out put, each wire has 3A inline fuse, that can be changed per need, but no more than 5A, total current for 5 wires no more than 20A.
Power Hub 1 Input & Output
Input, the max is 40A.
Out put, each wire has 5A inline fuse, that can be changed per need, but no more than 15A, total current for 5 wires no more than 40A.
