Outstanding 2K Quad HD 1440P + 1080P Video Quality
The INNOVV K6 dashcam features a front camera with a 2K Quad HD 1440P 30FPS resolution and a Sony STARVIS IMX335 Sensor, as well as a rear camera with 1080P 30FPS and a Sony STARVIS IMX307 Sensor.
*This combination captures high-quality video footage that provides greater clarity and detail. (The storage capacity of up to 256GB, which offers up to 33 hours of recording time.)
Equipped with F2.0 Aperture and 140° Wide View Angle
The F2.0 aperture and 140° wide viewing angle of INNOVV K6 dash cam provides a wider range of view, allowing you to capture more of your surroundings.
Mini, Simple and User-Friendly Installation Process
The DVR is creatively integrated into the front camera (80.5mm x 28mm), making it mini and easy to install without requiring disassembly of the motorcycle seat.
High-End Aluminum Alloy Construction
The K6 dashcam's aluminum alloy housing has a sleek metal texture and is expertly machined with a digital CNC lathe for excellent heat dispersion. It can withstand extreme outdoor temperatures from -30℃ to 70℃.
Features Loop Recording and Auto Emergency Lock
The loop recording & Auto emergency lock feature of INNOVV K6 dashcam ensures that important footage is saved and protected, providing peace of mind while on the road.
IP67 Waterproof Rating
With its IP67 waterproof rating allows the camera can be completely submerged in 0.5 meters of water for 30 minutes. No fear of any weather condition.
Easy-to-Connect Wi-Fi and User-Friendly APP
With built-in Wi-Fi connect & APP control feature, you can easily access and manage your dashcam footage through your phone.
Both motorcycle and bicycle versions are available, allowing you to choose the suitable one based on your vehicle type.
Available in Two Versions: Motorcycle and Bicycle
Motorcycle Version
Bicycle Version
Overview
*Not Included
What SD card to choice?Please purchase the branded SD card from reputable reseller. The brands like Samsung, Sandisk has too many fake SD cards. The resellers like INNOVV dealers, Samsung Amazon Store or trusted resellers. The size of SD card can be 32GB, 64GB, 128GB, 256GB. The speed of SD card is more than Class 10, U1, U2, U3. Click below link to get more knowledge about SD card. https://www.sdcard.org/consumers/faq/index.html#speedclass
What time can SD card record?256GB 19hours 128GB 10hours 64GB 5hours 32GB 2.5hours
Do I need to format SD card when first time to use it?No, You do not need it. But you need to format SD card in DVR via App before firmware upate.
Is pin side up to insert SD card to DVR?Yes, You are right.
11. How to update firmware?Please refer to: https://www.innovv.com/firmware-app
