The brand new INNOVV K5 dash cam is packed with features that no simple 'action camera' offers. It is designed and built for those who demand more.
K5 innovates with the Sony 8-megapixel sensor on the front camera, producing spectacular
4K Ultra HD footage at 30 FPS.
*The rear camera features Sony sensor, providing crisp and clear 1080P HD
Built-in Dual Band Wi-Fi & Full-Featured INNOVV App
You can connect your smartphone or tablet directly to the INNOVV K5 dash cam.
The dual band Wi-Fi (2.4Ghz / 5.8Ghz) is noteworthy for its fast transmission and more stability, giving you the ability to effortlessly view, download, and share your adventure with your friends via INNOVV App.
Stylish Appearance & IP67 Waterproof
The device is constructed of durable and lightweight aerospace aluminum alloys. It is also certified with an IP67 rating, meaning that it could withstand the rain, snow and dust. It is no doubt that the INNOVV K5 dash cam could perform well even in harsh weather conditions with its high-end design.
External Mic
Good Noise Reduction
INNOVV K5 dash cam adopts an external Mic instead of the internal Mic, upgrading the audio quality from a tinny sound to a resonating voice. It could clearly record your voices during road trip by attaching it to the helmet, making it a helpful gear for the motovlogging. What is more, it could record awesome engine or exhaust sounds by placing it on the right place.
.png)
NNOVV K5 innovates its GPS receiver with a high update rate of 5Hz, while the most dash cams are packed with the conventional update rate of 1Hz, creating more detailed and higher resolution tracking capabilities. With a fix update rate of 5, new location updates every second (5Hz) and a baud rate of 38,400 bits per second, the data uses 38,400 bits every second. For faster update rates, bits will be more and will be pushed to processor faster. It helps to decrease display lag time and improves distance measurements and tracking especially when moving on a curvy route at high speed.
Packed with Industry-leading 5Hz GPS Receiver
Auto On/ Off Recording Technology
All INNOVV dash cams are designed to operate in a “install & forget” manner. As soon as the ignition is turned on, the INNOVV dash cam will start to record automatically. When the ignition is turned off, the INNOVV dash cam will perform an automatic shutdown process.
GPS Indicator
Recording
Indicator
Function
Button
Wi-Fi Indicator
Smart Remote Control
You could conveniently check the Wi-Fi, DVR and GPS working status with the LED indicators on the Remote Control during your road trip without taking hands off the handlebar and eyes off the road.
MOTORCYCLE
ATV
UTV
SNOW MOBILE
BOAT
Intended For Powersports
(Motorcycles, ATVs, UTVs & Others)
Installation
Your INNOVV investment comes ready to play. Every single item needed to get you up and running is in the package. The accessories are professionally designed, and the install is simple and easy.
Overveiw
120° Angle View
Loop Recording
Parking Monitor
GPS
(Quick Connection)
Sony Image Sensor
Extreme Temperature Resistance
Support Up To 512 GB
MP4/ TS Format Supported
INNOVV K5 Includes Every Must-have Feature As A Dashcam
Specifications
*Those smartphones support the faster 5.8 GHz frequency Wi-Fi and play 4K videos (recorded by INNOVV K5's front camera) smoothly. Check the detailed smartphone list from
https://www.innovv.com/smartphone-list
