I recently bought a Innovv K3 system after I watched many Youtube channels. It is a very nice small system and I am very happy with the quality of the movies.
There is only one thing I want to improve and that is the vibrations during riding on the highway. I think that that is caused by the L-shaped mounting brackets. Is there a better solution for this "problem"?
Oke thnx, nice job for these days.
The rubber washers are just there to dampen vibrations. From my own experience I can assure you that they help. See an example of how I use them here.
Hi Hans,
Christmas greetings from Den Haag. The front camera is mounted on top of my headlight (BMW R1250 GSA HP 2019). Isn't it so that the rubber washers will increase the vibrations because there is more movement between the mounting bracket en (in my car) the headlight.
Hi Wim,
Greetings from Drenthe and welcome to this forum.
To reduce/prevent the vibrations, you can use the rubber washers supplied with the mounting set.
In addition, the cables coming from the camera may be too tight. And it also depends on where the cameras have been placed. For example, if these are placed on a vibrating fairing part, this also has an influence.
It is unfortunately a matter of try and error of where to place the cameras is my own experience.
