A few questions if anyone might know. 1.Does the Gsensor setting in app also affect the sensitivity in parking mode? 2. To connect to the DVR while bike is off, hit the power button. Is there a way to turn off the dvr with the power button or do you have to either power off via the app or cycle the bike on then off?
Thx
Hello,
1. No, the sensitivity of the G sensor has nothing to do with the parking mode.
The sensitivity of the Parking mode is fixed.
2. As long as the converter is connected correctly, the DVR can be turned on and off in sync with the device, without the need for a button.
Please check your Converter connection.
Thanks for the reply. It's not that I have an issue with powering the DVR on/off with the bike power.It did that just fine. I just inquired because if I want to check or change setting through the app, I don't usually want to power the bike on, so I hit the button.on the DVR. That works fine, but it seems the only way to power the unit off is to cycle the bike on then off. The power button doesn't seem to turn the DVR off.
Oh, to turn off the DVR by pressing button on the DVR, press for 5-6 seconds until it is turned off.
When DVR is working, press long to turn off, press pause to stop recording.
Great. That answers it. Just didn’t hold it down long enough. Info like that should be added to the in-box instructions. Thanks for the help.
