Set the sensitivity of the G-sensor as high as possible.
The sensitivity also depends on whether the motorcycle is shaken or bumped. The Innovv is more sensitive to shocks than to shaking.
The location of the canera also has an influence, plastic covers also dampen shocks.
So it is trial and error to find the right setting.
And what is also important, the blue LED of the power supply must be on. If it does not light up, the battery voltage is too low and the parking mode will be disabled, even if you have turned it on in the app.
This is to protect your battery from being drained.
Hi thanks for your reply I have turned the G sensor right down but you still have to really hot the bike hard to activate it I would of thought it would activate if someone rocked the bike or sat on it but it seems it will only activate if it is hit extremely hard
Also I have tried deleting the files as you suggested but once I have pressed edit and checked all box's the edit in the top right disappears and is replaced with cancel leaving you no option to delete files
Dito, it doesn't work, i gave up
Idem, j ai abandonné delà ne fonctionne pas
Hello, you can adjust the G sensor sensitivity here.
and This is in the advanced setting.
