Ok, I mounted the cameras hooked up all the wires, took the bike for a ride video looks really good. But the problem I’m having is the fact that in order to connect to Wi-Fi, I have to turn on the ignition switch. i can either run the bike , or run the battery dow, to make the connection. Seems to me that you sh be able to turn on the system to make adjustment, without the ignition switch. If there isn’t a way to do that, I think that putting a interrupting switch between the yellow wire, now going to the battery, so that you can manually turn on the system without starting the bike. Any suggestions.
That seems a little complicated just to check the setting. While i understand the reason for an always on camera system, the bike should not have to be on to do that. The remote should give you the option of starting the camera system without starting the bike. As I mentioned in my earlier post, I am going to install a single post switch on the yellow wire, then run that wire back to the battery. Turn on the switch and the camera starts. I don’t see any issues with doing that, your thoughts.
Hi
Hello.Thanks for your post. Right now we don't have this function but if you want to turn on the system without turn on the bike, you can disconnect the DC converter connector and then power the DVR with a power bank(output more than 1A) by a USB - Mirco USB cable.
