its would be along the lines of the C5 but with a daul lens
and an app for a PC so when you plug it into the PC via the usb you could set it up without haveing to use a wifi connection & phone
i dont use sound i use mny camrea to record my jurney & cover me in the event of an accident
20min file size which i beleive would be the maxium
& if possible a camnra that i could mount on my crash helemt & pluginto the system , the higher the camra is the better visiblilty for recording an event it would have
& if possible a 256gb card
& an overwrite facility so i wouldnt have to clear the card
Thanks for input. I'd like to review with you.
As you can see the C5 has bullet shape lens, the K1 has cube lens shape. Why do you like the K1 Cube shape lens?
That is easy, we can create text file or App for PC to do easy step up.
We always thinking about how to mount the camera system to helmet, but has good connection to power supply.
You can image, that mount the C5 on helmet, and then there is power lead from helmet to your jacket and then to battery, even we consider to disconnect the power cable from helmet to jacket, but still think it is a bit complicated.
Do you have any idea?
Why do you like the K1 Cube shape lens?.
no real reason just a personal preference
would be a good thing in Windows 10
We always thinking about how to mount the camera system to helmet, but has good connection to power supply. You can image, that mount the C5 on helmet, and then there is power lead from helmet to your jacket and then to battery, even we consider to disconnect the power cable from helmet to jacket, but still think it is a bit complicated. Do you have any idea?
i use heated garments (Keis) in the winter so the power takeoff could work along a similar line ?
when i get some time ill see if i can do a sketch
i have seen the sketch on the C5 forum
Since most use it as an event camera, add triggers such as the horn or extreme braking or crash detectio.
Thank you for your kind suggstions here and we would forward them to our relative colleagues to follow up.
