Clearly the APP is buggy, and quite confusing to many users as you can see by the forum conversations. Many people have simple questions about what setting does what, parking videos, G sensors…..etc. HERE IS AN EASY FIX…..1. Verify there is a confusion amongst users using the app (there definitely is!)…and simply place the little bubble with the “i” next to every single setting. When the user has zero idea what that setting does, or is confused (why choose 2G over the 5G option?, what to set the parking mode sensitivity to, and what that mode affects….etc….). So this little bubble with the “i”…..which explains every setting that a user can set…will almost certainly HELP every user, and hurt NOTHING. Not to mention it’s almost cost free. When it’s finished, push it out in the new firmware…..then we will all be informed of what does what. Read the forums. SO many people have questions about settings, and parking mode etc…..this is simple ONE day coding for a good coder. Could make the app go from ok, to “very good”….
KDog
Hi, Thanks for your valuable suggestion.
App program adjustment is not a easy task, but your suggestion is quite good, we will send this information to the R&D engineer and hope that we can make some adjustment in the future.
Thanks again.
