*Hi, we are having a eight-day break from September 28 to October 5, and may not be able to ship out the package and reply to your email on time. Thank you for your kind support.
Best/easiest way would be to use a cloud space like dropbox. Upload a video which you can't play, set it to "shared" and post the link to the share.
If the file is not too large, you could try uploading it directly to the forum. When writing a posting, you see some icons at the bottom. From the left these are "Add image / Add video / Add file / etc.". Use "Add file" to upload the video file.
i have tried both. formats. It could be my computer all I have is a Chromebook. The video starts to play and then stops as if it needs to buffer but the sound continues to play. I use VLC as that was recommended as a good app to play TS format.
Can you provide a sample video, which does not play correctly on your laptop?
What OS and video player are you using on your laptop to play the videos?
I have the same problem.. replay on my s20 is fine. My laptop does the same, plays for a few seconds then sound only
If possible, a short sample video file would help. This way we could check if the video file is corrupted or not.
What software do you use to play?
Do you record video in .TS format or in .MP4 format?
Please provide more information so that we can assist you better.
