The sensitivity of the parking sensor cannot be set. The g-sensor setting in the app is only for the sensitivity of the accident videos.
The parking mode also only works if your battery voltage is sufficient. If the blue LED on the power supply lights up, this voltage is sufficient.
If you tap the front camera with your fingers, does the parking sensor work? My experience is that the parking sensor is more sensitive to quick/short taps than just shaking the bike.
G senzor is not working,,,,the setting is in hight sensitivity
I aussi,alors que ma batterie est à 12,5 Lu
Hello, Could you describe the problem in more details? Or could you please contact cs@innovv.com for this issue?
Thanks.
