My K5 was working great earlier today. Now the control unit isn't lifgting up at all. Totally dead.
I checked to be sure the accessory yellow wire was connected and getting power. Nothing. I even placed the yellow wire on the positive batter terminal. Still nothing no light on the controller unit.
The DC converter has a red led led lit up on the side of it. I assume this means it is working. I understand this DC converter also provides power when the bike is off.
What should I do? What could be wrong? I even rechecked all of the connections, checked the inline fuse.
Hello Anderson
Could you check when you turn on the ignition, when color led light on the DC converter? the light should be blue flashing if everything is fine.
If it is blue led flashing and there is still no light on the remote control, please try to power the DVR with a power bank(out put more than 2A) and see if it is working or not.
The red light on the DC converter means your battery voltage is less than 12.5V when the ignition is off. it can not use the packing mode.
