The fit and finish of the Wi-Fi antenna is great, but it is made of a material that typical adhesives will not play nice with. Might it be possible to mold in an eyelet or round hole in an additional flange? Alternately, an adhesive backed, three side sealed, clear PVC pocket the item can slip into— like the type used to protect ID’s/workers badge, just sized to fit. It would make mounting easier. WI-Fi antenna was the only item in the K5 setup that slowed me down during install, because it should remain flat and not be bent.
Thank you for your kind suggestions here! We will forward this to our relative colleagues to further check for that.
