Hello, i have recently purchased the K5 set, unfortunately i had to mount the camera vertically,
so now i need to rotate my all my videos 90' right (the sd card port is the top).
Is there a setting to make that happen in the app or settings file ?
Maybe it needs to be added in firmware ?
If so, will it be available (to rotate recorded video 90',180',270') ?
Oh ok , thanks, major bummer....
By any chance maybe You can rotate the lens / only camera inside the unit so the effect is the same ?
There is only an option to flip the video by 180°, but not 90° or 270°.
I guess this is because the hardware resolution of the image sensor is 3864x2192. This allows an easy flip of the image, but a 90° rotation can only be done by software transformation if they want to keep the 4k resolution.
I don't know if there are any plans to add a 90°/270° rotation to the firmware.
@INNOVV MotoCam
Can you please tell something about whether it is planned to add the above mentioned rotation option to the K5 firmware or not.
