I just installed a K5 on my bike, and when I turn on the bike it starts recording as expected, however, when I start the engine, it stops recording. The recording light on the remote control starts flashing in an on-off-off pattern, which I don't think is mentioned in the manual.
Here's a video showing what I've described above:
https://share.vidyard.com/watch/PhxMGnBAcpyVqvXwJFe1Ly?
In the video I turn on the bike in the first few seconds (you can see the headlight illuminating), and then I start the engine at 30 seconds after the recording light has become solid, at which time the recording light starts flashing.
What could be causing the problem, and how can I troubleshoot it? What does the on-off-off flashing pattern mean?
Hello Daniel ,
It seems the SD card is not recognized, could you please choose another SD card and check? The K5 requires a SD card upto U3 speed, V30 or V60, or V90. And you are also suggested to disconnect the power converter, power the K5 with a USB power supply. Once you enter to the App, please formate the SD card and see if the problem can be sorted or not?
Thanks.
Some more observations:
On the first test ride, it seemed to record everything fine.
On the second test ride there was no footage recorded, but I didn't notice what the recording light was doing.
On the third test ride, I saw the flashing pattern when the bike started. Some time later when I was riding around, the light became solid for a while, but then it started flashing again.
