The price difference between which two do you mean?
Every Innovv camera has its own specifications and therefore prices can differ.But when I look at the title of your topic, do you mean that you want to buy a K5 with only one or two cameras? The K5 comes with two cameras. One camera is also the main unit of the system. This contains the electronics and SD card. Usually it is used as a front camera. The other camera is just a camera. this is often used as a rear camera.
Bonjour, il n'y a qu'une seule K5 dans la boutique. Ou confonds-tu actuellement le K5 avec les différentes versions du H5 ?
Every Innovv camera has its own specifications and therefore prices can differ. But when I look at the title of your topic, do you mean that you want to buy a K5 with only one or two cameras? The K5 comes with two cameras. One camera is also the main unit of the system. This contains the electronics and SD card. Usually it is used as a front camera. The other camera is just a camera. this is often used as a rear camera.
