The K5 turns on and remains on when I connect my Optimate 4 to the canbus on my GSA. It is correctly wired and the problem seems to be that with the charger connected the battery never drops below 12v. (This would normally trigger the unit to turn off. Problem is that with the unit constantly powered the front camera gets quiet hot. Without adding a kill switch or removing a the fuze Is there any other solution or has anyone else had the same issue? Cheers P
You have probably connected the yellow wire to a power supply that is switched on by the canbus of the optimate. Try to find another connection point for the yellow wire. I also use the canbus optimate (BMW K1600GT) and experience no problems with it.
Maybe this link can help you https://www.ukgser.com/community/threads/switched-live-gsa-1200-2017.299917/
Hi, même problème caméra front très chaude
