I have been reading and I have been experiencing that the K5 parking mode stays ON once you turn it on in the app. This includes while DRIVING It seems. This seems like a very easy fix for INNOVV…..why not have the code written so that when GPS is turned ON (with the key) the parking mode is disabled, then when the key is turned off, your last setting of PARKING MODE ON is then remembered. I think with parking mode constantly ON while driving I am getting dozens of accident videos every ride and I’m not having any actual accidents.
This does not match my experience. With parking mode enabled, the K5 enters parking mode whenever the K5 is turned off (means when the yellow cable "tells" the K5 that ignition is off). And runs at normal operation when turned on.
If you see a lot of protected videos, this might be because the G-Sensor for the crash protection is quite sensitive. Lower the sensitivity or disable it do avoid those false positive.
I have not experienced that
