Hi I am having problems with my k5 when I have turned off the ignition the camera keeps going and it gets hot so I have to disable the power supply to let it cool down can you please tell me what the problem is
Well...where did you connect the yellow wire to? Did you check that the voltage at the wire you connected the yellow cable to drops to 0V when you switch off ignition?
The K5 gets relatively warm/hot while running, but that is not an issue. On the desk my K5 gets around 40-45°C.
