I power up and ride from A to B then power off, about a 15 minute ride. Everything works well.
An hour later I power up again and ride from B to C and power off again, about a 25 minute ride. Later I find the last third of that ride is missing, not re-located to any other folder, simply missing presumed never recorded.
I power up again and ride the short distance home (C to B) and power down again, about 5 minutes. I notice the first 2 minutes of Cto B or so are also missing in the same manner as B to C.
Around the times that footage was missing, I noticed the camera LED winking at me on the control panel which will confirm the camera is not functioning.
Any answers?
It does indeed seem that the SD card is causing problems.
Do you have the option to test with another SD card?
What brand / model of SD card do you use, are the specifications sufficient for the K5?
Hello, it seems the videos are missing, please check if the videos are saved in other files such as "accident video" file, and also, as Randy suggested, you can change another SD card and try again.
Whats more, you are suggested to disconnect the power converter and only power the unit with a USB power supply, then check if the problem can be resolved or not.
Please contact us again if you have further questions.
Have you tried a different SD Card?
