I do not get anything to work well.
TS files cannot synchronize the sound. Is sometimes 10 seconds wrong.
MP4 files freezes in VLC and only sound continues. I have 1 minutes recordings.
Dashcam viewer is the buggiest program I've seen since the 80's. If you turn off the sound, you cannot turn it on again. No matter how you set the volume, it is still full. If you change the image source, the image will be completely black. Cannot go forward in the movie. Can't skip to the next movie, nothing happens.
Anyone have tips on guides to see if I'm doing things wrong?
Thanks. Will checka that out.
Non of my other programs show any promblems.
I also found lightworks and it works just fine, but Dashcam Viewer is just bug after bug.
Given your complaints, I suspect that there are problems with your PC. I do not recognize your mentioned complaints.
A manual for DashcamViewer can be found here https://dashcamviewer.com/resources/#documentation
The mentioned link does not work properly because of the # symbol. So just retype the complete link yourself.
