Hello from France
Can you please tell me if I could see the rear of the motorcycle in my cell phone when I am backing up (I have a BMW K1600 GT which has a reverse gear).
Can I use the rear view camera as an additional rearview mirror when connected to a phone (While driving or just backing up)
Thank you in advance for your answers..Sory for my English
Michel
PS I will connect the HINNOV K5 Cameras with the EZCAN or CANSMART system, do you have a tutorial ... or photos of connections
It's Urgent.....
Hello,
I have a question about the INNOVV K5 camera system.When I start my INNOV K5 system, I have to connect the system's WIFI to my Iphone 12, everything works fine.
Then, if I want to launch a SPOTIFY or WAZE sample application... I no longer have an internet network.
Is it possible to use the INNOVV application while driving (Display of the rear camera) with the SPOTIFY or WAZE applications which require internet access etc...
Thank you in advance for your reply
Best regards
Michel
Hello,
Are you sure that the INNOV K5 (Parking monitor) system works with EZCAN?
I got a message from EZCAN support telling me that it will not work with the yellow wire connected to EZCAN ...
The Red wire on the + battery and the black wire on the -Battery
Can you please inquire
Thank you and sorry to insist
Have a nice week end
Michel
PS Message from EZCAN:
Hi Michel
Glad the camera is working.The parking monitor feature will not work. Our device has a shut down sequence so it will not stay on. The Parking Monitor "feature needs constant power.
Kind regards
Jan
Good evening,
Please find in appendix the screenshots concerning the INNOVV application on my Iphone 12 Pro ..
Sorry in French ...
Regards
ok Thank you..I have to test again..and
Key protection video (what is it for?)
Maybe you're not shaking the bike hard enough ;-)
You cannot adjust the sensitivity of the parking monitor.
The sensitivity of the 'motion detection' is only for accidents recording.
Hello,
I connected the red cable to the + battery
I plugged the black cable into the - battery
I plugged the yellow cable into my EZCAN
Yellow Cable Test:
If I unplug the yellow cable from the EZCAN, the WI-FI: G5_INNOV_K5_102c6bd4d7 does not connect, and I cannot launch the INNOVV application on my Iphone 12 pro
If I plug the yellow cable into the EZCAN, the wifi: G5_INNOV_K5_102c6bd4d7 connects, I can launch the INNOVV application ... OK
I set the "Park Monitor" on
I position the "Motion detection" at the highest (Maxi bars)
I switch off the ignition, I wait 5 minutes then I shake my motorcycle.
Nothing is saved in:
Parking surveillance video
Accident video
Can I test by plugging the yellow wire into the + battery?
Thank you in advance for your help
Regards
Michel
OK Thank you very much Hans..have a nice evening
Good evening
This is a very good answer and I thank you for it.
Clearly this is the red wire on the + battery or the yellow wire on the + after contact that allows you to set up the parking monitor ?
As long as your K5 has power, the 'parking monitor' will work. The parking monitor is only activated by detected movements.
Hello,
I connected my 2 cameras like the attached diagram.
That is to say that the black cable, the red cable, the yellow cable are connected to the EZCAN system.
The cameras shoot very well ... no problem ...
Can you tell me if the "Parking Monitor" feature will work?
Thanks in advance
Regards
Hello
Everything is set up ... The Schroedie turn signals work fine .. even better than I expected .. It's connected to my EZCAN and so the diodes go out when I turn on the turn signals.after removing the turn signal, the diodes come back on gradually .. If I call the headlights 3 times, the diodes flash white .. like a strobe ...My accessory socket (cigar lighter) has become operational againINNOV K5 cameras are also installed on my EZCAN ... attached the wiring diagram with an EZCAN of Schroedie indicators
Have a good week-end.
Michel
Hello
In relation to my diagram, can you please tell me if my connections are correct?
Blue and black cable on EZCAN (Red Circuit)
I had connected the black cable and the 2 blue cables to the accessory cables (cigarette lighter).2 blue cables on the red cigarette lighter cable and black cable on the Brown cigar lighter.The problem is that I cannot leave the cables on the accessory (cigar lighter) otherwise when I recharge my battery, the indicator diodes light up ...
Even on the accessory socket which is under the battery.
Thanks in advance
Have a nice weekend
Regards
hello,
I just connected all the cables to the INNOV K5 system:
1 Remote control
2 GPS Module
3 Rear Camera
4 Micro
5 Smart Power SupplyI have a 256 GB SD card inserted.
The cables: Red Black and yellow from the Smart Power Supply are plugged into an EZCAN (White circuit)
Motorcycle with contact:Smart Power supply (Red Diode)
Motorcycle startedSmart Power supply (Blue Diode)
The Remote Control is offI can't find the system's WIFI
The INNOVV application is installed on an iPhone 12 Pro.I cannot display anything in the INNOVV application neither Camera nor Settings
Regards
Michel LAURI
Yes, all te parts of the K5-set are waterproof.
Hello,
I forgot to ask for the microphone.
Is it waterproof?
Thank you and good day
Regards
Thank you very much for your quick response
Michel
Yes, GPS and remote control are waterproof.
The microphone can be placed in the wiring harness of the right handle.
See also my installation on my BMW K1600GT https://www.innovv.com/forum/innovv-k5/and-another-installation-on-a-bmw-k1600gt-with-pictures I have no damage to fairing or cabling this way of installation.
Furthermore, the various parts have been hidden from view as much as possible.
The yellow wire must be connected to a switched power.
I have no experience with EZCAN, so no answer on that.
Hello
I'm sorry for my questions...
Are the GPS and the remote control waterproof? I imagine so?
Where is the best place to position the microphone on a K1600 GT?
What is the best installation and why:
Connect the 3 wires (black red yellow) of the Smart Power Supply to battery and yellow to + after contact
Connect the 3 wires (Black Red yellow) of the Smart Power Supply to EZCAN
Connect the 3 wires (Black Red yellow) of the Smart Power Supply to Black and Red wires on battery and yellow wire on EZCAN
For the moment, I have connected the 3 wires on EZCAN
Regards
Michel
