I'm thinking about buying a K5 system but have a question. Is it necessary to hook up the GPS unit for the camera system to work? I've read on these forums a number of people saying that getting the GPS unit to work has been problematic. I'll be mounting this system onto a 2020 Harley Limited, and don't want to mount the GPS unit out in the open. Will it work under the lid of the Tour-Pak which is fiberglass? If not, can I operate without the GPS?
I think it should be possible.
Try and see what happens. If you do not connect the GPS, make sure that no dirt and moisture can get into the connector.
Under the lid of fiberglass it should work.
I myself placed the GPS receiver under the plastic of my dashboard, no problems with reception.
Try to place the receiver as horizontal as possible for the best reception.
