I haven’t had a chance to test it but I installed the GPS module under the passenger seat do you think I will have reception issues? Also when mounted should the device be facing a certain way?
With the K2 I had the GPS antenna mounted under the passenger seat of my BMW K1600. I drive without passengers.
I have not had any problems with reception. But that does not mean that it also applies to you. It's try and error.
Unfortunately, the Innovv app does not have a GPS signal strength meter, so it would have been easier to test what the best place for the GPS antenna is.
You will quite certainly get reception issues with the gps mounted that way. It needs a cleary view to the sky. Not only straight upwards, but also sideways to, lets say 45°. And it should be mounted horizontally.
