Check the detailed and in-depth review of the INNOVV K5 by YouTuber Chaseontwowheels, including the unboxing part, installation part and road test part of the INNOVV K5.
Below are some comments for this review.
1) The external Mic of INNOVV K5 is regarded as the best one on motorcycle dashcam. You could kindly check the effect of the external Mic on 21:44.
2) The auto-on/off recording technology of INNOVV K5 is highly appreciated. You do not need to manually start or stop recording like using an action camera.
Other amazing reviews are available soon. π
Why did you put the front camera on the back of the motorcycle?
Hello Hans, they did that because the INNOVV K5 could better fit the motorcycle well.
As far as I have understood, they did this because the rear cam fits so well at the front nose. For just being a test, this is ok. But you are right....as a final solution, that would not make sense.
Am I right in assuming that they also tested an early sample of the K5?
At 10:20 he complains about the bolt in the clamp, which holds the remote control.
I have also criticized this point in my detailed review. And according to Innovv, the clamp has been revised accordingly.
@INNOVV MotoCam
As a response to the critics about the clamp/bolt in the video, I think it would be a good idea to post a picture of the revised clamp.
Hello, thank you for your kind suggestion here!
Yes, the INNOVV K5 reviewed by YouTuber Chaseontwowheels is also an early sample. We have made improvments for the GPS, remote control and others with the suggestions from INNOVV fans, like you! Many thanks for that.
@INNOVV MotoCam
But could you please post a photo of the new clamp?
@Frostie Hello, please kindly find the photo of the new way to install the remote control on handle bar with the phooto.
