How can I easily select and delete files in the protected files section? Doesn't give me the option. I am going on a big trip and want to be able to easily clear space as needed.
Unfortunately there is no way to delete files in the protected folders by app or by web interface. The only ways are...
Put the sd card in a computer to delete the files.
Connect the K5 to a computer by USB. This way the K5 starts as a storage device, giving you direct access to the sd card and allowing you to delete the files.
Both methods are not very pratical at a long trip. But you could simply disable the G-Sensor to avoid videos getting moved to the protected folder.
Thanks!
