HelloI recently install a K5 cam, and I noticed that the blue light o fthe DC power converter never goes even when the ignition is off.Is it normal ? Is there any risk that will impact the battery?thanks team
Hello,
Yes, never goes down :)
So it's a normal behavior, it's reassuring thank you
Never goes...... on or off? It's no problem if it doesn't turn off.
This indicates that there is enough voltage for your K5.
The K5 is equipped with the latest model power supply and this has no impact on your battery.
