I use a K5 on my bike, having problems with a blinking green light. I replaced the SD (memory card) it helped but still doing it. Anyone have suggestions?
That means the K5 detected a crash and saves the video in the parking/accident folder. Please check if your videos are there.
To prevent these false positives you can lower the sensitivity of the g-sensor settings.
Depending on your bike and the road conditions, even the lowest setting can still be too high so prevent false positives. In that case you should disable the g-sensor.
When it boots itself up it stays on green like it’s supposed to. I notice it blinking after I start riding. It blinks for awhile then comes on solid. Note when it’s blinking it doesn’t record. As far as formatting the SD card, I didn’t do that when it was new. So the answer would be no. Thanks Frostie
How does the flashing looks like? One flash per second or two flashes per second?
It is quite uncommon that the K5 stops recording and then, after a while, simply continues. That's why I suspect that the flashing simply means the g-sensor got triggered and the K5 saved the video into the parking folder.
Frostie it blinks twice a second.
Hi Dick,
does the LED blink right from the start? Or does it start blinking while driving?
Is the K5 recording?
Did you format the SD card by using the app? If yes, did it say "successfull" or did you get an error message?
