I've tried wiring my k5 unit into the tail light and now the fuse box feeling the instrument cluster on my 2019 Royal Enfield Himalayan. The unit boots up properly when the ignition is turned on in both instances. All the lights come on in the controller, both camera feeds are visible in the app, and the app indicates that everything is recording properly. Once I set off however the camera light on the controller starts to blink erratically while the others remain steady. Checking the footage after a ride, both in the app and on a computer, there are only infrequent recordings amounting to less than 1/4 of the time spent riding. I'm using a 512 gigabyte class 10 micro SD card from PNY.
I'm having the same problem With erratic recording can you help me out as well?
HI, I replied you by email, let's communicate it by email, Thanks.
