Camera does not work. There are no lights on the remote control. Fuse OK.
Power till camera OK!
The camera does not respond to external power supply.
It has worked for 4 months since installation, after motorcycle wasn't in use for 5 months.
1 season camera for 500EUR???
No lights on remote control in both cases.
Hi
Try with different SD cards.
Power measured till DC converter and after it.
Problem in camera!
Dear Yuriy
Sorry for the problem you got from the K5, Are there any videos in the SD card?
Is it possible for you to change another SD card and try?
Meanwhile, we are not quite clear when you said" power till camera OK", could you please let us know the exact meaning?
Thanks.
Is the blue led on the power module on or off?
If you power the K5 by USB (e.g using a wall charger), does it start?
How did you wired the K5? red/black to battery and yellow to switch 12V? Or are you using some kind of power adapter (e.g. Cansmart)
What does this exactly mean? Did you measure the voltage up to the power module? Or did you measure the voltage in the connector from the power module to the K5?
Do you mean you connected the power module directly to a 12V external power source? If yes, did you also connect the yellow wire to 12V?
