Hi, My K3 system wont stay on. The indications on the remote are video on, GPS on, then it goes off. This happens 3 times then the camera goes off. The power brick flashes blue as it should and when I run the cansmart diagnostics, i can watch the amperage fluctuate and then go to 0 when it turns off. The system was working fine for about 3 weeks then this happened on the trip back home. any guidance will help. This weekend I will disconnect each camera and the GPS to see if there is a failing component.
TIA
Greg
This is what I did today. I disconnected the rear camera, the GPS and the lights from the cansmart. I powered on the bike and the system worked. I was able to connect to it via WiFi and see what was recording. Next I plugged in the rear camera and tested, it worked. I then plugged in the GPS and tested. Everything worked, next 1 light at a time and everything worked. I did fine a pinched wire going to the rear camera so I re-routed it and put the bike back together. I will keep monitoring but for now it is working. Thanks for your help and tips.
Greg
Hi Greg,
What version of cansmart are you using? The two or the three-wire version?
And how did you connect the power module to cansmart?
Dear Greg
So sorry for the problem you got from the K3, could you please do below steps
1, disconnect the power converter and power the unit with a USB POWER SUPPLY.
2, if the problem persists, please disconnect two lenses, and only connect the rear camera in the front port, leave the rear port EMPTY.
Please let us know the result at your earliest convenience.
Thanks.
