Just installed a k3 system to my bike and the cameras record etc etc but I can see the live view to setup the angle of the cameras,I’m using a iPhone xs max with iOS 14.6. used another iphone and it work perfectl,any suggestions to get this to work on my phone.the app just displays this loading image forever so the systems not overly useful for me
I'm installing the K3 as I'm writing this and came to the same problem. The solution that worked for me was: Turning off cellular data on your phone under settings. I'm using iPhone 12 mini- if this matters.
My iPhone 11 Pro Max is on iOS 14.7.1 but there is no "Cellular" option under Settings? I have noticed that after the latest app and firmware updates downloading to the phone seems to be even slower than before. Also annoying that the app update reset everything - so I was recording in TS for several trips before I realised - and I can't even see TS files on the phone when I connect it to a PC, much less transfer them.
I am having the same issue with iPhone 12 Pro and iOS 14.7.1. Hope you find a solution soon.
Still no good after update,also tried it on a iPhone XR and it has the same issue
Any solution for this yet?
Thank you
Hi We are find the solution for this problem, I will reply you as soon as we have solution for it.
