I have ordered an innovv K3 on Amazon on April and I finally mounted it on my 1200 GS.
I have triple checked the connections and I have power coming correctly to the black box, but nothing append.
The main board seems to be out of order (see pictures). The 5v DC convertor is ok (blue light) but I see no light on the command (camera, gps or Wifi).
The innovv Wifi network is not available, and I cannot configure the device with m'y smartphone.
What did I missed ?
Thanks for your help.
Cyril
Thank tout both for your Quick answers.
I changed the way it was powered. I put it directly on the battery, and I only kept the 12v trigger on the ezCan.
I was misled by this article https://www.hexinnovate.com/2021/09/07/how-to-connect-your-innovv-camera-power-supply-to-a-hex-ezcan/
It works fine now
Hi Cyril,
the first thing I would check is whether the DVR itself is ok or not. This can easily be done by using a wall charger (with at least 2A) to power it by USB.
If the DVR starts up then, it is very likely it is ok.
If the above test has shown that the DVR is ok, next thing you should test is the yellow cable from the power module. The power module "tells" the DVR to start when it senses 12V at the yellow cable. That's why the yellow cable needs to be connected to switched (ACC) power. So for a test you can simply connect the yellow wire directly to the + of the battery. 10 seconds later the DVR should start.
If it does not, but the blue led on the power module is blinking, then there might be a connection issue between the power module and the DVR. So please check this connection then.
Hi Cyril,
please confirm if the bule light on the convertor is flashing or solid on? the normal working status should be flashing.
you could use the power bank (output 5V 2A) to connect and see if the DVR works?
