I have a 2019 Honda Forza 300. I recently purchased a K3. I would appreciate suggestions on where to mount the cameras and remote control. There are a lot of plastic panels that might be ok but maybe vibration would be an issue and render the cameras useless. I look forward to any pointers and help that may be out there.
Best regards,
Bernard.
Hi Bernard,
I have no experience with the Forza 300. But if I look at images on the internet you could place the front camera under the headlight. The rear camera may be placed to the left or right of the reflector above the number plate.Or maybe drill a hole above the reflector with the diameter of the camera and then place the camera in there.
As for the vibrations, if you use the rubber washers you already prevent a lot of vibrations.
