Hello, I have the K3. It seems that everything is the same as the K5 with the exception of the fron camera/module. Is it possible to purchase the K5 front camera/module and plug in all of my existing K3 hardware into it? Or are all of the connections different?
Thank you!
Hi, Christoph, Jade will take care of this through email.
The rear camera of the K5 is the same model as on the K3 (Sony IMX291LQR). So that should not be a problem. And I guess that the remote control is also the same.
I am not sure about the gps module. When I tested the K3, I accidentally mounted the gps of the K5 and got no values. So may be that the K5 gps is different from the K3 gps and you have to change it.
The connections are the same, so you can try it. You will probably have to reinstall your cables. All connections on the K5 are connected to the front camera of the K5 with a short cable.
