I first had the K3 on my Triumph Tiger 1200 and it worked fine, I've now moved it over to my new GS.
Went for a nice ride and then dumped all the footage into Dashcam Viewer and noticed lots of short video drop outs, anything from 5 seconds to 40 seconds, I've checked the time stamps in the videos and some footage is defiantly missing.
Last night I tested if it was a power issue by running the DVR from a USB power pack and disconnected from the bike power, still dropping video.
I have uploaded the latest firmware and formatted the SD card.. no better.
This image shows (the solid red line) where the video has dropped.
Not sure why this is happening, anyone else had this problem?
So after much testing swapping camera feeds around the conclusion was both cameras are fine and write 100% when only one camera is connected to the front DVR tail, so why does the video drop when 2 cameras are connected? Maybe the SD card is an issue so I tried a SanDisk card and it seems to work fine, I then did a speed read/write test on the Innovv supplied Intergral card V the SD card and found the following: Integral:
Writing Speed: 10.864 MB/s
Reading Speed: 21.477 MB/s
SanDisk:
Writing Speed: 78.988 MB/s < nearly 8 times faster
Reading Speed: 84.175 MB/s < 4 times faster
Both cards are the same spec.
yea I have looked, I've only got the one Video folder.
Hi, thanks for your reply, as per my post: I've checked the time stamps in the videos and some footage is defiantly missing. Ps, it's Rob not Bob :-)
Hello Rob, I want to check with you if the video is missing or the GPS is missing during that section?
Could you check all other folder if the video is there?
