Bonjour à tous,
Je viens d'installer une K3 sur ma moto, et après avoir tout branché, et mis en fonction, il n'y a que la led verte de la camera qui s'allume en fixe, celle du GPS clignote en orange et celle du wifi ne s'est jamais allumée et je n'est pas vu sur mon iPhone le réseau INNOVVK3.xxx .
J'ai mis à jour le micro logiciel (led verte clignote rapidement) mais pas de changement.
À votre avis que puis-je faire ?
Merci pour vos réponses
Cordialement
Hugues
Hello everyone,
I have just installed a K3 on my motorcycle, and after plugging everything in and turning it on, only the green camera LED lights up permanently, the GPS LED flashes orange and the wifi never turned on and I did not see the INNOVVK3.xxx network on my iPhone.
I updated the firmware (green led blinks quickly) but no change.
In your opinion what can I do?
Thank you for your answers
Cordially
Hughes
It may take a while for the GPS to get a fix for the first time. Does the GPS module have a clear view to the sky and is it positioned with the label on the GPS module facing up?
After updating, the WiFi LED should start flashing. If not, try updating again.
If you hold down the button on the remote control for 10 seconds (factory reset), what happens?
The supply voltage is good? The blue LED on the power module is lit?
Do you also want to check whether the connectors of the cameras are properly tightened?
Hello Hughes,
Could you take out the TF card , press and hold the remote control button for 10 seconds until the lights are off to reset the DVR?
Then please check if you can find K3 wifi in your phone wifi list.
If not, please turn off the bike, disconnect the DC converter , power the K3 with a powerbank or wall charger (5V 1A) through the K3 DVR MICROUSB port and see if you can find the wifi or not.
