HI, i just installed the K3. But it keeps disconnecting from wifi.
Everything is connected right, and i get all 3 lights solid, but after a couple of minutes, i loose wifi.
At 1st i was thinking its because battery volts dropped under 12.5, but it also does it when bike is running. Any thoughts?
Im an Android user too
I agree with Frostie, take a look at your wifi timer.
If there are no further problems with the recordings, there is a good chance that it is the WiFi timer. On the remote control, the recording and gps Led remain lit?
Maybe you enabled the Wifi-Timer at the K3. This would make the K3 to shut down Wifi after the set time.
