Hello,
I installed an INNOVV K3 setup earlier this year. Last week, the system seemed to have stopped recording (no longer solid green) and is now flashing a green light every second. Per the manual, a flashing green light every second simply means "not recording."
I've re-formated the Micro SD card, with no success.
I've tried updating the firmware, still flash green every second
Even without a Micro SD card in the DVR, the system still flashes green every second
Please advise.
Hello,
Could you disconnect your rear camera and only connect the front camera and check if it works?
If not, could you disconnect your front camera then only connect the rear camera with the front camera connector and check if it works?
Flashing once per second indeed means that no recording is taking place. So even if no SD card is inserted.
Have you tried another SD card yet? SD cards can also malfunction.
Can you see in the app whether the SD card is detected?
