Is there a way to adjust the focus of the K3 cameras? They appear to focus very close (5 feet) and everything else is a bit blurry. My K2 cameras do not have this issue.
Hi, have you swapped the front connectors of the cameras, the middle cable is Front camera cable,we checked here and the dvr work ok, could you please swap the two camera? For the "Video Sharp" issue, these pictures seems be compressed, could you send us the original videos from the rear and front camera? Our engineer will analyse the problem accordingly, could you send to videos to dropbox or cs@innovv.com?.😉
Hi ,the focus of the k3 is fixed, could you please let us know if both 2 lenses are a bit blurry or just 1 lens? Is this bit blurry video appear in the first time you use the K3 ? Would you please check if there is any cover in the lens? Thanks for your answer in advance.
The K3 system has only been on three or four short (10 min) rides. First videos look sharp, so maybe the lens shifted. Both lenses are clean with no cover (cleaned with micro fiber). Both lenses are sharper up close, but the rear is worse (note: the camera on the rear of my motorcycle is identified as the front camera by the software).
I have 6 Innovv systems (5 K2 systems and one K3 system). All K2 systems are sharp close up and far away after several years of riding.
yes, we get the mail and will submit to the engineer soon. We will contact you via mail.
Email sent. Thanks for looking into this.
