Hi, I’ve just finally fitted my K3 to my Tenere700 and it’s seems to have an intermittent fault, everything fired up and records then every so on the camera symbol on the controller will flash slowly and go solid again…
secondly the gps was working fine whilst fitting and setting up, first ride out today it just flashes :( (although I have just tried moving it further away from the dvr so fingers crossed that might solve it?)
there seems to be no reason or pattern to the camera issue Any thoughts?
On flash a second I think, just a slow on off, def not a double pulse…
yep that’s why I’ve moved it, I’m limited with space and where I can put it due to it being a fairly slim/smaller bike
...then every so on the camera symbol on the controller will flash slowly and go solid again…
1x flash/second or 2x flashes/second?
Where did you mount the GPS? It should be mounted horizonal and really needs a clear (unblocked) view to the sky.
